Author Topic: Focusrite LiquidMix (2006)  (Read 4505 times)
« on: March 14, 2015, 08:27:51 AM »
Production of the Focusrite Liquid Mix was discontinued in April 2010.
http://www.soundonsound.com/sos/sep06/articles/liquidmix.htm
http://global.focusrite.com/downloads?product=Liquid+Mix
http://web.archive.org/web/20090307015239/http://www.sweetwater.com/store/detail/LiquidMix/
Liquid Mix v1.5 features software solutions for PC and all Macs, including Intel Macs, and operates within every major sequencer, including both Pro Tools HD and LE (version 7.0 and above, using included VST/RTAS wrapper). Version 1.5 is available as a download from Focusrite's website.
Focusrite's Liquid Mix is a DSP-powered add-on for your computer that hosts a large range of compressor and equaliser plug-ins, all created using a novel form of convolution technology to measure and then emulate the audio characteristics of hardware devices. We carried a fairly detailed preview a couple of months ago, but now that the production version (v1.2) is shipping, we've had a chance to put all its emulated EQs and compressors to the test and also to try out some small updates to the original software.
For the benefit of those who may have missed our preview, the Liquid Mix is based on the DSP-powered compressor and EQ sections of Focusrite's Liquid Channel, and packages these processes into plug-ins that can be used in a Mac or PC-based recording system. Up to 32 channels of EQ and compression can be used at the same time via the insert points and busses of your chosen DAW software, and because the plug-ins run on the Liquid Mix's DSP rather than the host CPU, there's very little extra load on the computer, even when the maximum 32 channels of processing are running.
Compressor Emulations
Flat Comp / Clean Sound Free Controls
Focusrite Liquid Channel DSP compressor.
Trany C / US Classic Discrete 1C
Based on an API 2500 stereo mastering compressor, serial number 0016 (Old/Normal/Hard settings).
Trany A / US Classic Discrete 1A
Based on an API 2500 stereo mastering compressor, serial number 0016 (Old/Normal/Soft settings).
Silver 2 / US Modern Tube 1
Based on an Avalon VT737SP valve channel strip, serial number 28150.
Live Sound / Brit Live Sound 1
Based on a BSS DPR402 dual compressor/limiter, serial number 02-9983-B.
London / Brit Boutique Tube 1
Focusrite Liquid Chiswick
Based on a Chiswick Reach stereo valve compressor, serial number RMS0061.
Wasp 2 / Brit Classic Solid State 1
Based on a Drawmer DL221X, serial number 1008X.
Wasp 1 / Brit Classic Tube 1
Based on a Drawmer 1960 tube compressor, serial number 1002.
Big Blue A / US Modern Solid State 1A
Based on a Dbx 160S compressor/limiter, serial number 000004 (standard compression setting).
Big Blue B / US Modern Solid State 1B
Based on a Dbx 160S compressor/limiter, serial number 000004 (Over Easy compression setting).
US Radio / US Classic Solid State 1
Based on a Dbx 165 compressor/limiter, serial number 1821.
Copy Cat / US Modern Copy Cat
Based on a Empirical Labs EL8 Distressor, serial number 1689.
Vintage / US Vintage Tube 1
Based on a Fairchild Model 670, serial number 530.
FF ISA 130 / Focusrite Classic ISA 130
Based on a Focusrite ISA 130, serial number F00069T.
FF Green 5 / Focusrite Green Channel Strip
Based on a Focusrite Green channel strip, serial number GO05116.
FF Red 7 / Focusrite Classic Red 7
Based on a Focusrite Red 7, serial number FO6350T.
Dunk A / US Modern FET 1
Based on a Manley Slam!, serial number SLAM120 (FET limiter).
Dunk B/ US Modern Optical 1
Based on a Manley Slam! serial number SLAM120 (ELOP opto limiter).
Primitive / US Classic Tube 2
Based on a Manley stereo 'variable mu' compressor, serial number MSLC61536.
Big Green / Brit Classic Optical
Based on a Joemeek SC2 compressor, serial number 05-1038.
New Age 2E / US Modern Hybrid 2E
Focusrite Liquid STT1-2
Based on a Millennia STT1, serial number 0-161 (solid-state input, solid-state compressor settings).
New Age 2A / US Modern Hybrid 2A
Based on a Millennia STT1, serial number 0-161 (tube input, tube compressor settings).
Class A 1 / Brit 70's Class A 1
Based on a Neve 2254/A dual/stereo compressor/limiter, serial number 5008K.
Class A 2 / Brit 70's Class A 2
Based on a Neve 33609/B dual/stereo compressor/limiter, serial number 108.
Brit Desk 1 / Brit Classic Desk 1
Based on a Neve VR console compressor, serial number unknown.
Meat Pie/ Brit 60's Class A
Based on a Pye 84 4060/01 compressor/limiter, serial number 60.
Grinder A / Brit Modern Desk Copy A
Based on a Smart Research C2 buss compressor, serial number C217.
Grinder B / Brit Modern Desk Copy B
Based on a Smart Research C2 buss compressor, serial number C217 (Crush setting).
Mix Buss / Brit Classic Buss
Based on an SSL FX G384 stereo compressor, serial number FX384-180.
Brit Desk 2 / Brit Classic Desk 2
Based on an SSL SL4000 G+ console compressor, serial number unknown.
Brit Desk 3 / Brit Modern Desk 1
Based on an SSL SL510 5000-series dynamics module, serial number unknown.
Acme 1/ US Modern Tube 3
Based on a Summit DCL200 dual compressor/limiter, serial number 0721076.
Acme 2/ US Modern Tube 4
Based on a Summit TLA100A tube levelling amplifier, serial number 0120429.
Leveller / US Classic Tube 3
Based on a Teletronix LA2A valve compressor/limiter, serial number 00227 (silver face, pre-Harman).
Brit Tube / Brit Modern Tube 1
Based on a TL Audio C1 dual valve compressor, serial number 121739.
Viking 1 / Danish Classic Tube 1
Based on a Tube-Tech CL1B compressor, serial number 04150.
Viking 2 / Danish Classic Tube 2
Based on a Tube-Tech LCA 2B dual/stereo compressor/limiter, serial number 04010.
Stellar 1 / US Classic Solid State 1
Focusrite Liquid UA2
Based on a Universal Audio 1176LN (reissue) mono limiting amplifier, serial number 1394.
Stellar 2 / US Classic Solid State 2
Based on a Urei 1176LN mono limiting amplifier, serial number 11854 (silver face).
Stellar 3 / US Classic Solid State 3
Based on a Urei / Teletronix LA3A mono levelling amplifier, serial number 1584 (black face, 30dB switch setting on rear panel).
Stellar 4 / US Classic Optical 1
Based on a Urei LA4 compressor/limiter, serial number 4832A (silver face).
EQ Emulations
Class A 2 / Brit 70's Class A 2 EQ
Based on the four-band EQ section of a Neve 1073, serial number 1742.
Trany 4 / US Classic Discrete 4 EQ
Based on an API 550B four-band EQ, serial number 02212.
Trany 5 / US Classic Discrete 5 EQ
Based on an API 559 nine-band EQ, serial number AX-GP-02211.
Old Tube 1 / US 60's Tube 1 EQ
Based on a Pultec EQP1 three/four-band EQ, serial number 1253.
Old Tube 2 / US 60's Tube 2 EQ
Based on a Pultec MEQ5 three-band EQ, serial number 1742.
Platinum 1 / Focusrite Platinum Voice Master EQ
Focusrite Liquid V Master
Based on the five-band EQ featured on the original Focusrite Platinum unit, serial number P070110.
ISA 115 / Focusrite ISA 115 EQ
Based on a Focusrite ISA 115 six-band EQ.
Clas A 4 / Brit 60's Class A 3 EQ
Based on the three-band EQ section of a Neve 1058 channel strip, serial number 375.
Trany 3 / US Classic Discrete 3 EQ
Based on an API 550A four-band EQ, serial number 3855.
Silver 3 / US Modern Hybrid 3 EQ
Based on an Avalon VT747SP six-band EQ, serial number 27093.
Old Tube 3 / US 60's Tube 3 EQ
Based on a Pultec EQH2 three/four-band EQ, serial number 6140.
Vintage 3 / US Clasic Discrete 4 EQ
Based on an EAR 822Q three/four-band EQ, serial number TH82.
Brit Desk 4 / Brit Modern Desk 4 EQ
Based on the six-band EQ section of a single module from an SSL E-series desk.
Brit Desk 5 / Brit Modern Desk 5 EQ
Based on the six-band EQ section of a single module from an SSL G-series desk.
Huge Tube / US Modern Tube 6 EQ
Based on a Manley Massive Passive six-band EQ, serial number MSMPX1100.
Brit Desk 6 / Brit 80's Classic Desk 1 EQ
Based on the six-band EQ section of a single channel from an Amek Angela console, serial number 01314.
Silver 2 / US Modern Tube 1 EQ
Based on the five-band EQ of an Avalon VT737SP channel, serial number 12545.
Silver 4 / US Modern Tube 1 EQ
Based on the four-band EQ of an Avalon 2055, serial number 10747.
Platinum 2 / Focusrite Platinum Bass Factory EQ
Based on the seven-band EQ featured on the Japanese-only Platinum Bass Factory, serial number P060929.
Zebra 2 / US Zebra Discrete Desk Copy EQ
Based on the Chandler Limited EMI Passive TG Abbey Road.
« Last Edit: October 24, 2018, 04:29:02 PM by chrisNova777 »
