RME Digi 9652 Project Hammerfall (1999)
http://www.soundonsound.com/sos/sep99/articles/rmehammer.htmRME DIGI 96/8 PAD
http://www.rme-audio.de/download/968pae.pdf(some of these cards are mac g5 compatible, some are not)
edirol UA5 (march 2002)
![](http://media.soundonsound.com/sos/mar02/images/edirolua5front.gif)
http://www.soundonsound.com/sos/mar02/articles/edirolua5.aspM-audio Delta 66 /w Omni I/O breakout box option (january 2001)
http://www.soundonsound.com/sos/jan01/articles/maudio.aspthe cable connecting the delta + omni i/o box is called a male to female db15 cable you can buy a longer cable for more distance between the card + the breakout box
motu 828 (2001)
![](http://www.macos9lives.com/downloads/_img/motu_828.jpg)
more info:
http://www.soundonsound.com/sos/jul01/articles/motu828.aspmore info:
http://www.soundonsound.com/sos/apr01/articles/applenotes.htmmotu 896![](http://www.macos9lives.com/downloads/_img/motu-896.jpg)
more info:
http://www.soundonsound.com/sos/jul02/articles/motu896.asp![](http://www.macos9lives.com/downloads/_img/wordclock.jpg)
wordclock compatible
motu 1224![](http://img.audiofanzine.com/image.php?lang=en&identifier=id&size=normal&module=product&product_id=1754)
connects via 324 PCI card | can combine with the 2408 + other motu systems
driver download :
http://cdn-data.motu.com/downloads/pci424/pci_os9.hqxContains audio drivers and application consoles for MOTU PCI-424/324 audio hardware, which includes the 2408 mk3, 24 I/O and HD192.Double-click installer and follow on-screen instructions.
Motu 2408 (feb 1999)
![](http://www.macos9lives.com/downloads/_img/motu_2408_mk1_front.JPG)
![](http://www.macos9lives.com/downloads/_img/motu_2408_mk1_rear.JPG)
eight, 20-bit analogue inputs and outputs
article:
http://www.soundonsound.com/sos/feb99/articles/motu2408.654.htm![](http://www.macos9lives.com/downloads/_img/wordclock.jpg)
Motu 2408 Mk2 (2000)
http://www.sonicstate.com/digital/model.cfm?modelID=1299&manid=57&manuf=57The mkII version is no different from the original except that the analog in/out has been upgraded to 24bit on balanced TRS connectors.
Motu 2408 Mk3 (2003)
http://www.soundonsound.com/sos/oct03/articles/motu.htmm-audio duo (2002)
![](http://media.soundonsound.com/sos/oct02/images/maudioduo.gif)
more info:
http://www.soundonsound.com/sos/oct02/articles/maudio.aspopcode datport
http://www.soundonsound.com/sos/jul99/articles/opcodedat.htmdigidesign mbox (2002)
connects via usb | allows use of pro tools LE software (under os9 + mac osx)
![](http://akmedia.digidesign.com/products/images/prd_enl_2620_5542.jpg)
MORE INFO:
http://www.soundonsound.com/sos/jun02/articles/digidesgnmbox.aspm-audio Mobile Pre USB (2003)
EASILY CONFUSED WITH THE AUDIOPHILE USB~! MOBILE PRE HAS NO MIDI
compatible with os9 | allows use of pro tools m-powered 7+ (under mac os x 10.4+)
driver download:
http://akmedia.digidesign.com/support/compressed/MobilePre_USB_Installer_1_5_2f1_77194.sitfirstgen:
![](http://www.core-sound.com/mobilepre-usb/mobilepre_large.jpg)
http://web.archive.org/web/20030401224338/http://www.m-audio.com/products/m-audio/mobilepre.phppress release:
http://www.m-audio.ca/images/en/press_releases/M-Audio_MobilePre2_PR.pdfrevision looked like this:
M-audio transitcompatible with os9 | allows use of pro tools m-powered 7+ software (under mac os x 10.4+)
![](http://www.dancetech.com/aa_dt_new/hardware/images/dt_items_164446.jpg)
larger image:
http://cdn.head-fi.org/e/e7/e71fe538_Transit+(01).JPGM-audio groovelab![](http://img6.imageshack.us/img6/2301/soft32ala.jpg)
manual:
http://www.m-audio.ca/images/global/manuals/GrooveLab_Quickstart.pdfroland m1000 digital mixer audio interface
![](http://media.soundonsound.com/sos/may06/images/qab1rolandm1000.l.jpg)
connects via usb | 4 spdif inputs + 1 stereo analog input = 10 channels
manual:
http://lib.roland.co.jp/support/en/manuals/res/1811166/M-1000_Manual_e1.pdfhttp://c1.zzounds.com/media/quality,85/M-1000_R-79ab0526f7d26301f8e57f726eae36ad.jpghttp://www.soundonsound.com/sos/jun03/articles/rolandm1000.aspedirol m-100fxThe M-100FX is a 10-channel Audio mixer with a number of useful Voice & Sound Processing effects.
![](http://www.dancetech.com/aa_dt_new/hardware/images/EDIROL_M-100FX_main.jpg)
connects via usb | not bus powered
rear image:
http://www.roland.com/products/en/M-100FX/images/image_02_L.jpgmanual:
http://www.roland.com/support/article/?q=manuals&p=M-100FX&id=1811410driver:
http://www.roland.com/support/article/?q=downloads&p=M-100FX&id=1812824edirol ua1ex
edirol UA-3FX
roland UA-5 (2001)
![](http://www.roland.com/products/en/UA-5/images/top_M.jpg)
http://lib.roland.co.jp/support/en/manuals/res/1811507/UA-5_egfis3.pdfEcho Gina (24-bit)(1999)
![](http://img.audiofanzine.com/image.php?lang=en&identifier=id&size=normal&module=product&product_id=700)
![](http://www5f.biglobe.ne.jp/~kame/gina.jpg)
(revision of the pci card)
http://files.echoaudio.com/manuals/echo24_mac_manual.pdfdriver:
http://files.echoaudio.com/drivers/mac/install_echo24_6.04.hqxa note on combining multiple echo 24bit devices
Esync cables come with Gina24, and can be used to daisy chain several 24-bit Echo cards together. Esync is a
proprietary form of super clock that allows you to sync together multiple 24-bit
Echo products. Simply attach the Esync cable to the two-prong “Esync Out”
connector on the Layla24/Mona/Gina24 PCI card, and attach the other end to
the “Esync In” connector on your Gina24 PCI card.
Echo Darla (24-bit) (1999)
![](http://www.pcrecording.com/darlalarge.jpg)
Echo Gina (20-bit) (1997)
![](http://hp.vector.co.jp/authors/VA018718/towns/junk/gina01.jpg)
connects via PCI
os9 driver:
http://files.echoaudio.com/drivers/mac/install_echo_card_4.0.hqxarticle:
http://www.soundonsound.com/sos/1997_articles/dec97/eventgina.htmldriver downloads:
http://echoaudio.com/pages/mac-os-x-software (scroll to the very bottom option)
manual:
http://files.echoaudio.com/manuals/gina_mac_manual.pdfWARNING: Not all Darla 20, Gina 20, Layla 20, and Darla24 cards are compatible with Power Macs. Unfortunately, this is a hardware incompatibility; as such, it cannot be worked around in software. When using these products, you may experience lockups or your Power Mac may not function reliably. Consequently, Echo Digital Audio will not provide technical support for these drivers.
Echo Digital Audio assumes no liability or responsibility for damages caused or loss incurred as a result of you downloading and using these drivers. You use this software solely at your own risk.
m-audio delta 410![](http://www.soundland.de/catalog/images/products/tn/22/224950-306x311.jpg)
connects via PCI | DOES NOT ALLOW USE OF PRO TOOLS M-POWERED ON MAC (except on xp using cracked mp7)
can be combined with up to 3 other delta cards to add addtional i/o
emagic audiowerk2 (1999)
![](http://media.soundonsound.com/sos/jul99/images/emagicaw2_1.gif)
connects via pci | developed for os9 | EASI drivers are Emagic's own proprietary driver (like ASIO)
article:
http://www.soundonsound.com/sos/jul99/articles/audiowerk.htmdriver :
http://mac.brothersoft.com/emagic-audiowerk-driver-download.htmlnot reccomended but could work out great if bought for a low price
emagic audiowerk8 (1997)
![](http://www.macos9lives.com/downloads/_img/emagic_audiowerk8.jpg)
Audiowerk8 is a Digital Audio Recording PCI-card for MacOS or Windows with Digital I/O (S/P-DIF), 8 analog Outputs, 2 analog Inputs.
Cascading 3 cards is possible, which will give the user 2 Ins and 24 physical Outs.
article:
http://www.soundonsound.com/sos/1997_articles/jul97/audiowerk8.htmlnot reccomended but could work out great if bought for a low price
audiomedia III (1996)
![](http://i.ebayimg.com/00/s/MTQzNFg4MjA=/z/rnkAAOxyY9VRMSYZ/$T2eC16d,!wsE9suwywDJBRMSYZIBHw~~60_35.JPG)
![](http://archive.digidesign.com/support/propix/images/AM3outs.gif)
specs:
http://archive.digidesign.com/support/specs/toolbox_specs.htmldriver:
http://archive.digidesign.com/download/sndrvr/allows use of pro tools LE software up to version 5.1.1 os9 | 6.2.3 osx | 6.1.1 winxp
g3/g4 compatibility info:
http://archive.digidesign.com/compato/osx/tb/am3.cfmmore info:
http://www.soundonsound.com/sos/1996_articles/jul96/digidesignsession.htmlyamaha ds2416 (1998)
![](http://data.yamaha.jp/sdb/local/products/images/9298/12073/9298_12073_1.jpg)
connects via pci
article:
http://www.soundonsound.com/sos/oct98/articles/yamahadspf.htmlmanual:
http://www.ds2416.org/xpisoftware/Manual/DS2416.pdfdriver info:
http://www.sonicstate.com/news/2001/04/06/new-mac-drivers-for-yamaha-cards/driver downloads:
http://www.megatrade.ru/English/Yamaha_Support.htmlterratec-producer-phase-26-usb
![](http://img209.imageshack.us/img209/6315/bild1lx0.jpg)
manual :
http://ftp.terratec.com/Producer/PHASE/PHASE26USB/Manual/PHASE26USB_Manual_GB.pdfThe MAC OS 9 drivers.The PHASE 26 USB System is equipped with a special ASIO driver. The MIDI port is notavailable under MAC OS 9. Furthermore, the Sound Manager is not supported. Thefunctions of the ASIO ControlPanel are pretty much identical to those of the WindowsVersion. In the version that is currently being shipped, direct monitoring is not supportedby the MAC OS9 ASIO driveropcode DATporthttp://www.soundonsound.com/sos/jul99/articles/opcodedat.htm]http://www.soundonsound.com/sos/jul99/articles/opcodedat.htm
opcode SONICportopcode SonicPorthttp://web.archive.org/web/19991006112043/http://www.opcode.com/products/sonicport/http://www.soundonsound.com/sos/apr04/articles/terratecphase88.htmesi gigaport (2002-2006)
http://download.esi-audiotechnik.com/download/esi/gigaport_ag/gigaport_ag-english.pdf8 output USB Audio Interface
Sonorus StudI/O (1998)
http://www.soundonsound.com/sos/sep98/articles/sonorus.htmlAlesis ADAT edit (1999)
![](http://www.sweetwater.com/publications/sweetnotes/sn-latesummer99/graphics/adatedit.jpg)
an adat interface card for mac os 9.. comes with software made by emagic
article :
http://www.soundonsound.com/sos/aug99/articles/alesisadat.htm http://www.sweetwater.com/publications/sweetnotes/sn-latesummer99/page11.htmlhttp://alesis.com/stuff/contentmgr/files/0/9d2b1fc3c579211a294dbd112724fbbe/file/adatedit_manual.pdfroland rpc-1
http://www.rolandus.com/products/details/344
