Author Topic: Finally got Homebrew to install! on El Cap  (Read 938 times)
« on: September 16, 2023, 01:06:28 PM »
this is not easy for most boxes running el cap..
if you give up easy dont even try this! lol
some downloads that helped me make this happen:
download GIT installer for macOS..
https://github.com/timcharper/git_osx_installer
cMake for macOS...
https://cmake.org/download/
if u get a SHA256 error or Curl Error u have to delete the file it lists and try again with -f flag
also another important factor in getting it working is writing a Curl preferences file in your home directory
the path + filename would be ~/.curlrc i think.. but i think youll be ok if u add the following lines that fix the SSL errors + SHA256 errors
Code: [Select]
--insecure
--location
-H  "Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"
-H  "Upgrade-Insecure-Requests: 1"
anyway im glad to be able to install the missing software packages to be able to make better use of the unix subsystem of macOS using the "brew" commands
heres a guide - i didnt use thsi guide tho
https://digitizor.com/install-homebrew-osx-el-capitan/
https://brew.sh/
Re: Finally got Homebrew to install! on El Cap
« Reply #1 on: September 16, 2023, 06:01:25 PM »
« Last Edit: September 16, 2023, 06:35:59 PM by chrisNova777 »
