Author Topic: Nektar Midiflex - the dawn of a new era! XP compatible  (Read 1366 times)
« on: March 21, 2023, 10:40:44 PM »
https://nektartech.com/midiflex-4-usb-midi-interface/?fbclid=IwAR0oDq-8dcLiPYfWUDhKr-42nRh2udjtj8QNGdhlP4Ps7xkgANzSC2On1d8
There’s a New MIDI Interface In Town
The Nektar MIDIFLEX4 is a 4-port MIDI interface with flexible routing, splitting, and merging. Unlike flimsy plastic interfaces, MIDIFLEX4’s roadworthy housing sports a sleek wrap-around aluminum cover for years of reliable service. Designed for flexibility, MIDIFLEX4 can easily be adapted to the ever-changing MIDI connection requirements of your growing studio or road rig. It can be used as a 1-in/3-out, 2-in/2-out or 4-out interface on macOS, Windows, and iOS.
SPECIFICATIONS
USB class-compliant MIDI interface
 4 configurable MIDI Ports: 1 in / 3 out, 2 in / 2 out, 4 out
Automatic MIDI in-/output detection
Multiple MIDIFLEX4 units can be used at the same time to expand the number of MIDI ports
2-1 MIDI merge or 1-3 MIDI split box in stand-alone mode (requires optional USB power supply)
Aluminum housing with 4 port status LEDs, 1 power LED and mode button
Powered by USB or optional external standard USB power supply
Includes standard USB cable and Bitwig 8-Track software license card
Works with any MIDI music software on OS X, Windows and Apple iOS
Connections: 4 x MIDI DIN socket, 1 x USB B plug
Dimensions: 11,1 cm (L) x 6,5 cm (D) x 3,3 cm (H)
Weight: 180 gr
(*= requires Nektar DAW Integration)
SYSTEM REQUIREMENTS
USB class compliant (no driver needed)
Windows XP, Vista, 7, 8, 10 or higher. Mac OS X 10.5 or higher, Linux (Ubuntu).
Compatible with Apple iOS (requires camera connection kit)
IN THE BOX
MIDIFLEX 4 USB MIDI Interface
Standard USB cable
User Guide
Bitwig licence card
MIDIFLEX 4: EXPAND YOUR MIDI PORTS
The Nektar MIDIFLEX 4 USB MIDI interface brings flexible MIDI connections to any MIDI setup on MacOS, Windows or iOS. The 4 MIDI ports can be configured as 1 in / 3 out, 2 in / 2 out or 4 out interface – and if you need even more ports, simply connect another MIDIFLEX 4 to expand your MIDI power!
MIDIFlex 4 LEDs
ALL THE RIGHT PORTS, INSTANTLY.
No driver required: The MIDIFLEX 4 is USB class-compliant, so setup is practically instant! Simply connect the MIDIFLEX 4 to your computer and the ports become available in your DAW software’s MIDI settings.
Automatic port detection: Even better, MIDIFLEX 4 also automatically detects if a MIDI In- or Output is connected and displays the setting with its MIDI port LED indicators. So just connect your external MIDI gear and let MIDIFLEX do the rest. The 4 LEDs indicate if a port is configured as In- or Output.
Expand your ports with multiple units: We know that it’s never enough – if you need more ports, simply connect another MIDIFLEX 4 for more ports!  For instance with 3 MIDIFLEX 4, you could build a system with 4 MIDI Ins and 8 MIDI Outs!
And if that’s still not enough, you could always add another one…
MIDI Interface MIDIFLEX 4 back side
MIDI MERGE AND SPLIT FEATURES
MIDIFLEX 4 is more than a USB MIDI Interface: In stand-alone mode it can work as a MIDI split- or merge-box. Simply power it from an external power supply and select the mode you want using the dedicated button at the top of the unit. You can use it as a 2-1 merge or 1-3 split box.
Midiflex Mode Switch
CAPTURE YOUR IDEAS –
BITWIG 8-TRACK DAW INCLUDED
MIDIFLEX 4 comes with a license for Bitwig 8-Track. With this DAW you can start producing, performing, and designing sounds like a pro from day one. Bitwig 8-Track includes over 50 software instruments and effects for use on up to 8 audio or MIDI project tracks, and you can use any 3rd party VST® plug-ins you might own, too. The ‘Bitwig Essentials Package’ comes as part of this package as well, featuring a highly versatile handpicked selection of loops, clips and samples, to make it even easier to get you started.
Re: Nektar Midiflex - the dawn of a new era! XP compatible
« Reply #1 on: April 04, 2023, 05:39:49 PM »
SYSTEM REQUIREMENTS
osx Leopard.. i wonder if it will work on a PPC powermac g3/g4/g5 too
thast cool that its compatible with iOS aswell.
