Author Topic: Virtual FX Rack Vol 1 by Steinberg (1995) for Cubase-TDM  (Read 3151 times)
« on: August 04, 2019, 01:43:32 AM »
http://cd.textfil.es/cubase/INFORMAT.ION/FX_RACK.TXT
made for CUBASE use with Pro Tools TDM Hardware
   Virtual FX Rack Vol. 1
                          Effects Plug-Ins for TDM
 Hamburg  -  The new Steinberg-Technology package for TDM contains
five important DSP based effect programs that no studio should
be without. Finally the 'Outboard Gear' requires no additional
rack! But more importantly it all works without crackles, noise
and buzz - The complete signal-path and inter-effect connections
all exist in the digital-domain.
The sound quality of the effects is all up to the Steinberg
standard - first class and easy to use. For many musicians it's
a dream come true. Need some reverb? then drag a reverb into the
signal path - done. Maybe a little real-time chorus for the
guitar? Help yourself to creamy  chorused guitar - and all
before you found the first working patch cable. With TDM and the
Virtual Effects Rack you have limitless effect possibilities.
Exactly the right mix.
Users of Cubase Audio can integrate this TDM-Technology into
their complete MIDI and Audio recording environment.
 The Virtual Effects Rack includes:
PANdora - Stereo Autopanner
 The perfect tool for stereo effects. The Pandora is designed to
work without demanding too much DSP power. It can be used in
multiple signal paths simultaneously. Various waveforms allow
abrupt swings or smooth glides in the stereo image.
 Hallelujah! - Chorus
 A  totally new concept: Adjust the Glimmer-Parameter and find
yourself in a new world of chorusing. Your singer becomes a
choir, and your guitar becomes a super wide sensation. You can
choose between mono or stereo operation.
 PlateRunner  - Stereo Reverb
 The classic reverb for every occasion, now as a handy TDM-
Plug-In. It doesn't get simpler than this. It's always there to
help create the right ambience. Totally in real time, naturally
in stereo  and  self-explanatory.
 Stereo Wizard - Enhance your mix!
 Made for those who cannot get enough stereo - the Stereo Wizard!
But be careful, there is a limit to how much stereo one pair of
ears can take.
 Y-cables - For flexible mixing, routing and patching.
 That little extra something for flexible mixing. Y-cables simply
split a signal into two outputs or combine two inputs into one
output. What was earlier impossible in the digital domain, but
so common in the real world, is now a TDM- Plug-In. Saving the
best until the end... they don't use up a valuable DSP! They
work on the same DSP as Pandora or Hallelujah.
 System requirements:  The Steinberg Plug-Ins require a TDM
equipped Mac or PowerMac.
Further information is available from:
Steinberg Digital Audio GmbH
f.a.o. Thomas Wendt
Eiffestr. 596
20537 Hamburg
Tel:      040 - 210 330
Fax: 040 - 211 598
c  Steinberg Digital Audio GmbH 1995.
Offline smilesdavis
Re: Virtual FX Rack Vol 1 by Steinberg (1995) for Cubase-TDM
« Reply #1 on: July 28, 2022, 06:37:52 AM »
we need guis of those :)
Offline smilesdavis
« Reply #2 on: August 11, 2022, 06:04:50 PM »
ill get em run onmy tdm rig
