Author Topic: 19" dbx 231s graphic equalizer  (Read 3607 times)
« on: January 18, 2019, 07:28:44 PM »
https://dbxpro.com/en/products/231s
Specifications
Input Connectors   1/4" TRS, female XLR (pin 2 hot)
Input Type   Electronically balanced/unbalanced, RF filtered
Input Impedance   Balanced 40k ohm, unbalanced 20k ohm
Max Input   >+21dBu balanced or unbalanced
CMRR   >40dB, typically >55dB at 1kHz
Output Connectors   1/4" TRS, male XLR (pin 2 hot)
Output Type   Impedance-balanced/unbalanced, RF filtered
Output Impedance   Balanced 100 ohm, unbalanced 50 ohm
Max Output   >+21dBu balanced/unbalanced into 2k ohm or greater; >+18dBm balanced/unbalanced (into 600 ohm)
Bandwidth   20Hz to 20kHz, +0.5/-1dB
Frequency Response   <10Hz to >50kHz, +0.5/-3dB
Dynamic Range   Typically >112dB
Signal to Noise Ratio   Typically >95dB
THD+Noise   <0.003%
Interchannel Crosstalk   <-90dB, 20Hz to 20kHz
Bypass Switch   Bypasses the graphic equalizer section in the signal path
Low cut Switch   Activates the 50Hz 12dB/octave high-pass filter
Range Switch   Selects either +/- 6dB or +/-12dB slider boost/cut range
Operating Voltage   100-240VAC 50/60Hz
Power Consumption   15W
Power Connector   IEC receptacle
Unit Weight   6.2 lbs.(2.81 kg)
Shipping Weight   7.9 lbs.(3.58kg)
Dimensions   3.5" (8.9cm) H x 6"(15.24cm) D x 19" (48.26cm) W
