Author Topic: m-audio delta 44 (1998)  (Read 3828 times)
« on: November 07, 2017, 07:50:18 PM »
https://web.archive.org/web/20000304202836fw_/http://www.midiman.com:80/Html/products/delta44.html
https://web.archive.org/web/20001205112900fw_/http://www.midiman.com:80/m-audio/html/products/delta44.htm
https://web.archive.org/web/20000303220703fw_/http://www.midiman.com:80/Html/drdelta.html
http://www.m-audio.ca/products/view/delta-44
Delta 44 Now shipping! (msrp: $399.95)
New Mac Drivers Delta 44, version 0.4 now available!
The Delta 44 is the only computer interface you will need to input and
output 4 channels of analog audio from your computer -- all at an
affordable price and at the pinnacle of 24-bit 96kHz fidelity. The Delta 44
system includes a PCI card connected to a sturdy analog break-out box. The
break-out box provides four analog audio input and output jacks (1/4" TRS),
compatible with balanced or unbalanced, +4dB or -10dB signal levels. Also
included is Delta Control Panel software which allows you to control the
Delta 44's comprehensive routing, monitoring, and mixing capabilities.
Features:
4x4 24-bit/96kHz full-duplex recording interface.
Configured as a PCI Host card with external audio break-out box.
4x4 analog break-out box accepts balanced or unbalanced connections on 1/4" tip-ring-sleeve (TRS) jacks.
Analog I/O configurable for +4dB or -10dB signal levels.
Measured D/A specs: 103dB (A-weighted) dynamic range, 0.0015% THD @ 0dBFS.
Measured A/D specs: 99dB (A-weighted) dynamic range, 0.0023% THD @ 0dBFS.
All data paths support up to 24-bit/96kHz performance, no upgrades necessary.
Powerful digital mixing, routing and monitoring capabilities.
Includes Windows 95/98, ASIO/ASIO2, Mac, DirectX and Windows NT drivers.
Minimum System Requirements:
Windows 95, 98 or NT
Pentium II 266MHz - (96kHz operation)
Pentium 200 MMX - (48kHz or less)
128 MB of PC100 RAM - (96kHz operation)
64 MB of SDRAM - (48kHz or less)
UDMA EIDE or SCSI HDD
Macintosh: G4, G3 or G3 accelerator
« Last Edit: November 07, 2017, 11:14:02 PM by chrisNova777 »
