Author Topic: 19" echo layla (1998) 8in/10out wordclock spdif midi  (Read 4097 times)
« on: March 05, 2017, 07:57:41 AM »
http://dlia.ir/Scientific/Magazines/SoundandMusic/Sound.On.Sound.Magazine.Sound.Music/1999/Event%20Layla-SOS-feb.pdf
http://www.pcrecording.com/laylarev.htm
http://bdm.cc/2014/02/adat-layla/
article here
https://web.archive.org/web/19990128203425fw_/http://www.event1.com:80/products/layla.html
manual:
https://web.archive.org/web/19980710183041/http://event1.com:80/download.html
https://web.archive.org/web/19990824161659/http://event1.com:80/download/layla_gina_darlaMacdriver.html
SPECIFICATIONS
Layla Professional Digital Multitrack Recording System
Audio Performance
(Analog in to analog out)
Frequency Response: 10Hz - 22kHz, ±0.5dB
Dynamic Range: >98dB
THD+n: 0.005% 20Hz - 22kHz
Hardware
Host Interface: PCI bus card
PCI bus master interface
Eight 1/4" TRS balanced analog inputs with precision 20-bit 128x oversampling analog-to-digital converters
Ten 1/4" TRS balanced analog outputs with high-performance 20-bit 128x oversampling digital-to-analog converters
S/PDIF digital I/O with up to 24-bit resolution
On-board 24-bit Motorola 56301 (80MIPS)
24-bit data resolution maintained throughout internal signal path
Word clock/superclock I/O
MIDI in/out/thru
EasyTrimª automatic input gain adjustment circuitry
Support for continuous sample rates with single Hertz resolution
Software
Full duplex operation (simultaneously record ten channels while playing back 12 channels)
Software controllable input levels
Includes mixer application for audio inputs and outputs, monitor assignments, volume, pan, and metering
Includes Syntrillium Software's Cool Edit Pro-Special Edition multitrack recording/editing software
Includes Sonic Foundry's Sound Forge XP 4.0 graphic waveform editing/DSP effects software
Includes Sonic Foundry's CD Architect professional Redbook audio CD mastering software
System Requirements
PCI 2.1 Pentium system running Windows 95
16MB RAM (32MB or more highly recommended)
PCI bus slot
Re: echo layla (1998) 8in/10out wordclock spdif midi
« Reply #1 on: December 12, 2017, 01:48:45 AM »
a note frm the manual on using more than one interface from event/echo
"fortunately, your new layla will operate with gina + darla in the same system! "
